Will this help
  • Graphics Cards
  • MSI
  • Windows XP
  • Graphics
December 29, 2001 2:49:59 PM
an MSI mobo(DDR).... to replace a i dont know wha u call it mobo :) ...
pentium 2 to Athlon XP 1500...
an MSI geforce 2ti 200....
will it help my fps go higher from 60?(counter-strike)
can it go to 99?
will there be a huge difference?
please tell me, im gonna buy it soon if i get bad comments from you guys... :)
More about : question
December 29, 2001 3:06:10 PM
Yes, your FPS will be way higher! There will be a difference!
AMD technology + Intel technology = Intel/AMD Pentathlon IV; the <b>ULTIMATE</b> PC processor
December 29, 2001 3:06:11 PM
December 29, 2001 3:46:56 PM
One thing to think about if you do go for the faster system (and all of us would aggree that you should do the upgrade:)  Make sure that you get a new powersupply and that it fits in your case. AMD prosessors need more power and cooling that your average (or above average for that matter) Pentium II. I highly suggest that if you have 1 HD, a CD/DVD ROM drive, and a CD Burner, that you get a 350-400 Watt Powersupply from Antec, Sparkle, or other brand named retailer. (NO GENERIC) This way, you should have no problems when playing games, or running other programs.
Also, make sure that you have one case fan in the front, and one in the back. This will help your Prossessor stay cool.
Remember to formate your HD and start afreash with a clean machine when doing any major upgrade and make sure that you will not need any old ISA devices as most new MB do not support them.
If it works for you then don't fix it.
