Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
xp pro, wireless broadband, still works. just wanting to share folders
between 2 wireless pcs. after login, wallpaper appears and thats it! i can
run programs via task manager, but trying explorer.exe brings the desktop
then dissappears. any ideas? thanks in advanced.
Mark L. Ferguson
FAQ for Windows Antispy http://www.geocities.com/marfer_mvp/FAQ_MSantispy.htm "mike" <mike@discussions.microsoft.com> wrote in message newsB7A8CCA-75DD-41E4-9D0F-E9D4BFFFBCE2@microsoft.com...
thanks for the reply. unfortunately did not work. anything else? thanks again.
mike
"Mark L. Ferguson" wrote:
> Taskbar Repair Tool Plus!:
> http://www.kellys-korner-xp.com/taskbarplus!.htm >
> Mark L. Ferguson
> FAQ for Windows Antispy http://www.geocities.com/marfer_mvp/FAQ_MSantispy.htm > "mike" <mike@discussions.microsoft.com> wrote in message newsB7A8CCA-75DD-41E4-9D0F-E9D4BFFFBCE2@microsoft.com...
To repair all system files, go to Start/Run, and type (or paste in): SFC /SCANNOW
If no help, try a Repair, or 'upgrade' setup.
If you run an XP "Upgrade"setup, from the original, or "Gold" version of the setup CD, and you have SP2 installed, it might go into
a setup loop, and you could lose your install. Uninstall SP2, BEFORE you Upgrade setup from CD (that lacks sp2 on it.)
Mark L. Ferguson
FAQ for Windows Antispy http://www.geocities.com/marfer_mvp/FAQ_MSantispy.htm "mike" <mike@discussions.microsoft.com> wrote in message news:BB932C4E-EBED-43BC-9908-5DC1429AF3D0@microsoft.com...
> mike
>> http://www.kellys-korner-xp.com/taskbarplus!.htm >>
>> Mark L. Ferguson
>> FAQ for Windows Antispy http://www.geocities.com/marfer_mvp/FAQ_MSantispy.htm >> "mike" <mike@discussions.microsoft.com> wrote in message newsB7A8CCA-75DD-41E4-9D0F-E9D4BFFFBCE2@microsoft.com...
