Problems with my new MX 400. Driver Related? Help!
  • Graphics Cards
  • TV
  • Computer
  • Graphics
Anonymous
a b U Graphics card
January 3, 2002 2:31:32 AM
i bought a new AOpen MX400 64MB AGP TV Out card this past week...
after sorting out problems with the TV Out i solved all of that... BUT....
it seems after 10 minutes of playing like F1 2001 or AOE 2 or any other game, my computer re starts itself!
a buddy of mine with a similar card has problems in windows with the computer just randomly restarting!
i think the drivers are shitty... anything i can do ?? anyone know anything? Thanks for any help!
More about : problems 400 driver related
January 3, 2002 3:56:42 AM
Post your system specifications. It sounds like a Power Supply problem. It could be that your mobo can't supply enough power to the AGP slot. Or your power supply is too weak.
Anonymous
a b U Graphics card
January 3, 2002 7:26:31 PM
i have :
p3 450
asus p2b M/B
128 Ram
1 40gb 7200rpm
1 20gb 5400rpm
MX400 64mb AGP
1 cdrom
1 burner/cdrom
1 ethernet
1 SB Audigy
my power supply is old it came with the p3 when i bought it like almost 3 years ago.
that could be the problem! [-peep-]! i dont wanna spend more money :)
January 3, 2002 11:57:44 PM
what is the output of your power supply on watts?
Anonymous
a b U Graphics card
January 4, 2002 12:39:20 AM
wow... am i reading this right...
135 Watt P/S !? that doesnt sound too good :(
January 4, 2002 1:44:24 AM
Your power supply is probably not capable of sustaining that many components. Upgrade to a 300 watt PS if you can.
Anonymous
a b U Graphics card
January 5, 2002 6:49:52 PM
i bought a new AMD and P4 approved HEC 300 WATT power supply
i just ran F1 2001 and it locked up again!
HELP!
Anonymous
a b U Graphics card
January 5, 2002 9:13:59 PM
I am having a similar problem but with a Inno3d GeForce 2 Ti 64. My computer will freeze up within the first minute of game play in both F1 2001 and in the new wolfenstein game.
I am running the newest NVIDIA drivers 23.11 but have tried all the other ones.
Indicently there is a similar discussion on http://www.atomicmpc.com.au/forum.asp?cat=te&top=19992 as well as on the INNO3d Website. http://www.inno3d.com/q_a.html. This may help some of you.
Anonymous
a b U Graphics card
January 5, 2002 9:37:53 PM
i formatted and reinstalled XP , everything is running good.. latest drivers.. new good P/S
its gotta be the drivers, dOH !
January 6, 2002 1:41:28 PM
If u have the detonator drivers it may be a problem. A friend of mines restarts whenever those drivers are loaded
