Archived from groups: alt.internet.wireless (
More info?)
I want to connect my 3 home computers to the intenet via my Wireless
Broadband.
Comp #1 the host:
The D-Link AirPlus DWL-520+ Wireless PCI is connected to my rooftop
antenna.
The Realtek RTL8169/8110 Family Gigabit connects to my Netgear Wireless
Router.
I can move files across the network but I cannot access the internet from
Comps #2 and #3.
Comp #2 has a Samsung Wireless PCI
Comp #3 has a Netgear Wireless PCI
What am I doing wrong?
Listed below are the ipconfig details
Thanks
Remove the 8's correct email col888@idl.com.au
Windows IP Configuration
Host Name . . . . . . . . . . . . : Netgear2000
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Mixed
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Wireless Network Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : NETGEAR WG311 802.11g Wireless
PCI A
dapter
Physical Address. . . . . . . . . : 00-09-5B-92-19-56
Dhcp Enabled. . . . . . . . . . . : No
IP Address. . . . . . . . . . . . : 192.168.0.15
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.0.1
DNS Servers . . . . . . . . . . . : 192.168.0.1
Comp #1
Host Name . . . . . . . . . . . . : amd2600
Node Type . . . . . . . . . . . . : Unknown
Ethernet adapter Local Area Connection:
Description . . . . . . . . . . . : Realtek RTL8169/8110 Family
Gigabit
Ethernet NIC
Physical Address. . . . . . . . . : 00-0D-61-2A-5C-8E
Connection-specific DNS Suffix . : idl.net.au
Description . . . . . . . . . . . : D-Link AirPlus DWL-520+
Wireless PCI
Adapter
Physical Address. . . . . . . . . : 00-80-C8-AA-AB-F0
Dhcp Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
IP Address. . . . . . . . . . . . : 172.16.5.221
Default Gateway . . . . . . . . . : 172.16.5.1
DHCP Server . . . . . . . . . . . : 203.33.254.161
DNS Servers . . . . . . . . . . . : 172.16.1.1
Lease Obtained. . . . . . . . . . : Wednesday, 2 June 2004 9:31:50
Lease Expires . . . . . . . . . . : Wednesday, 9 June 2004 9:31:50
PPP adapter IDL Wireless Broadband:
Description . . . . . . . . . . . : WAN (PPP/SLIP) Interface
Physical Address. . . . . . . . . : 00-53-45-00-00-00
IP Address. . . . . . . . . . . . : 203.34.9.187
Subnet Mask . . . . . . . . . . . : 255.255.255.255
Default Gateway . . . . . . . . . : 203.34.9.187
DNS Servers . . . . . . . . . . . : 203.32.82.6
203.32.82.5
Comp #2
Host Name . . . . . . . . . . . . : amd2400
Description . . . . . . . . . . . : SAMSUNG 11Mbps WLA
Physical Address. . . . . . . . . : 00-02-78-E2-1E-4C
IP Address. . . . . . . . . . . . : 192.168.1.10
Comp #3
PCI Adapter
The Netgear Wireless Router WGR614 is 192.168.0.3
