Archived from groups: alt.internet.wireless (More info?)
"mhicaoidh" <®êmõvé_mhic_aoidh@hotÑîXmailSPäM.com> wrote in message
news:_Fmvc.36061$js4.15601@attbi_s51...
> Taking a moment's reflection, Hamish McStill mused:
> | Is kitchen foil okay?
> If it weren't, it wouldn't be "home" made ...
Thought maybe that really shiny foil used in heating and airconditioning
might be better.
made a pair of small curved reflectors that work really well here.
hardware store has alum rolls of roof gutter flashing for about $2.00us per
meter and about $1.50us for a big thick styrofoam picnic cooler. Used
clear packing tape to stick shaped styrofoam to hold the reflector curve top
and center. Poked some plastic tube thru that foam at the right spot and
now I can just slip them over antenna's. Straight edge and the back side
of a knife scored the alum just right to snap off the dimensions ,,,
neater/easier than cutting crooked with tin snips.
Took a whole lot more time to drive to the hardware and walk in/out of the
grocery store for the cooler than it did to make a pair of pretty usefull
things.
"Hamish McStill" <chap2003@hotmail.com> wrote in message
news:nNmdnZc6trsvmSPdRVn-uA@comcast.com...
> might be better.
> Thanks,
> Ham
What did you use for a pattern or where did you get the dimensions, etc.?
Tx,
H
"bumtracks" <user@unknown.org> wrote in message
news:ZZnvc.9712$x9.7882@nwrddc02.gnilink.net...
per
top
side
> things.
> > might be better.
> > Thanks,
> > Ham
yep,,, print out the curve a couple times at different sizes until you like
what you see
then just cut it out , tape it down to a piece of foam, and take a hack or
whatever saw blade to a couple or more pieces of stacked foam and make it
neat later.
news:VWpvc.7618$sI.5638@attbi_s52...
etc.?
> Try here, mate. I used the EZ-10 templates. They also have templates
> and instructions on the curved type mentioned, presumably, by bumtracks.
> http://www.freeantennas.com/ >
