Need help!
  • Graphics Cards
  • Graphics
January 16, 2002 1:28:12 PM
This is actually for one of my friends but I cant figure it out so i turn to you guys =].....
his specs:
amd athlon 1.2ghz (nothing overclocked)
asus a7v mobo with latest bios
geforce 2 mx 400 (pny)...
23.11 dets and via 4.37 4 in ones
antec case with antec 300w power supply
windows 2000
ok his problem is that he has lockups after about ten minutes and his cpu temps are low so it cant be cpu failure....and he didnt get the lockups when he had an ati radeon video card...I have no clue why its doing this...because he did a fresh install of drivers and totally remvoed the old ati ones...anyone have similar problems or have any ideas..
also we set everything in bios to "safe" and it still locks up...very strange
Thanks!
More about : question
January 17, 2002 3:37:20 PM
Check if your voltages are stable.
My case has so many fans that it hovers above the ground :eek:  .
Anonymous
a b U Graphics card
January 17, 2002 3:52:49 PM
Set the PC Probe to log everything. Then just run the computer until it crashes. Check and see if there was any change in the voltage. If there was anything, try a different PS.
AMD: Join the rebellion!
