GeForce 2 GTS and TV out problems
  • Graphics Cards
  • TV
  • Monitors
  • Geforce
  • Graphics
Anonymous
a b U Graphics card
a b C Monitor
January 17, 2002 3:33:14 PM
I have had my GeForce 2 GTS for a while now, and I thought I would try to connect a television to it to sit along side my monitor. When I did this, the TV did not work. Now, if I disconnect the monitor and start the computer with the TV attached, it works. If I then try to attach the monitor, the monitor still doesn't work.
I am using the latest 21.83 drivers from Leadtek. I have Windows XP. AMD XP 1700+, Soyo Dragon Plus mobo with 512 DDR 2400. Sound is onboard from C-Media. The GeForce is the only card I have plugged in. No PCI cards. Ethernet is also onboard. 400W power supply. RAID stripe 0 on 2x20 Maxtor 7200 rpm hardrives (new).
Can anyone give me some advice?
Thanks,
Steve Campbell
More about : geforce gts problems
January 18, 2002 5:40:59 PM
Welcome to the world of nVidia TV-out. If you want it to actually work then get an ATI card.
Knowan likes you. Knowan is your friend. Knowan thinks you're great.
