Radeon 8500 Dual Monitor
  • Graphics Cards
  • Dual Monitors
  • Radeon
  • Graphics
Anonymous
a b U Graphics card
January 22, 2002 4:52:15 PM
My system: Athlon 1.2, 512 MB SDRAM, Win2k Advanced Server, Radeon 8500
I'm trying to run dual monitors with the card but the second monitor (the DVI port one) flickers and i can't change the refresh rate from 60 hz to 85 hz. Anyone know how i can fix this? I've tried using the latest drivers but still no go. Thanks.
More about : radeon 8500 dual monitor
January 23, 2002 8:18:13 PM
DVI monitors typically run at a 60 kHz refresh rate, which works fine on a flat panel/lcd screen. I take it you're using the dvi to "standard video" adapter included with the card.
I don't know of a solution myself. Is anyone else having this problem?
Knowan likes you. Knowan is your friend. Knowan thinks you're great.
