A problem
  • Graphics Cards
  • Graphics
Anonymous
a b U Graphics card
January 27, 2002 7:22:21 PM
i got a nvidia riva tht2 graphics cardd and when i start my computer up it starts normaly then when i resart it, it only starts in safe mode. So i remove it from the device manager aand it starts up fine. and i restart agian and it won't start in normal mode
HELP PLAESE
More about : problem
January 27, 2002 7:43:14 PM
First off the first time it starts up does do you have all your colors IE 16, 32 bit as opposed to 16 colors. If you do not I belive your problem is your drivers. Reinstall them and you should be fine.
Good luck
Keyboard not found press F5 to continue
January 28, 2002 9:56:38 AM
Try other (newer) drivers, maybe your drivers are giving a conflict.
My case has so many fans that it hovers above the ground :eek:  .
