Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Control Taskbar Autohide... Launch Control Panel "Taskbar ..
Forum Windows XP : Windows XP General Discussion - Control Taskbar Autohide... Launch Control Panel "Taskbar ..
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
So, step back... I want a single desktop click to enable/disable
windows XP taskbar autohide.
I can do this if I write a script for the AutoHotkey macro tool to open
the relevant dialog box and then check or uncheck the appropriate
checkbox.
I'd like to open the dialog box with a command line from AutoHotkey, or
a similar operation. Right-clicking the taskbar even in the program is
uncool. (It's also tricky if the taskbar is moved around.)
The catch is, I can execute any CP dialog EXCEPT this one as a command
line, either passing a dialog parameter to Control.exe or else using a
*.cpl file name with Control.exe or directly. But I can't find
"Taskbar and Start Menu".
So I'm stuck. Help will be gratefully received.
Sponsored Links
There are 1129 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
