Yes No
Ads
Tom's Hardware > Forum > Computer Brands > Dell > Inspiron 5000 and wireless networking
Forum Computer Brands : Dell Inspiron 5000 and wireless networking
Archived from groups: alt.sys.pc-clone.dell (More info?)
Hello,
I am wondering in anyone out there has tried to put a
mini pci wireless network card and antennas into an
Inspiron 5000 laptop? I am thinking about removing the
modem I have in mine and putting one in and I just wanted to see if anyone
had been able to first.
Thanks
Reply to Anonymous
I've got the same computer...some time ago, I put a PCMCIA card in
(supplied by the ISP) and it worked OK. Be sure you have enough RAM or
else the system may very well bog down. Probably 512 meg will be good.
Tom S.
Houston, TX
David Mason wrote:
> Hello,
> Thanks
Reply to Anonymous
- 0 +
On Fri, 1 Jul 2005 07:09:11 -0500, "David Mason"
<davidm001@centurytel.net> wrote:
>Hello,
The modem and wireless go in different plugs, so there's no reason to
"remove" the modem.
I believe the antennas are built into all inspirons, but certain
models also have an auxiliary antenna. I believe the 5xxx series is
one of them. As far as Dell-OEM mini-pci versus a PCMCIA wireless,
it's tough to say which is better. Your Dell Resource CD will
probably be helpful in case a driver issue arises.
Installing the mini-pci Dell wireless card is almost as easy as
inserting a DIMM. The hatch is underneath the computer, next to the
"M" (memory) hatch. Push the card firmly into the slot, push the card
downward until it snaps into place, then put the tiny antennas on
(MAIN wire is white; AUX wire is black). They'll probably be held
down by masking tape, which can be removed.
Dan
Reply to Dan
You'll need a PCMCIA card, not a mini PCI card. There is no antenna
inside the 5000. The system predates the coming of common wireless by a
few years.
David Mason wrote:
> Hello,
> Thanks
Reply to Anonymous
Is there one inside the 5150?
Cyndi
"Edward J. Neth" <ejn63@netscape.net> wrote in message news:CQjxe.19778$GH6.5281@newssvr17.news.prodigy.com...
> few years.
> David Mason wrote:
> > Hello,
> > Thanks
Reply to Anonymous
- 0 +
On Sun, 03 Jul 2005 13:35:54 GMT, "Cyndi" <noonehome@nowhere.com>
I didn't know much about the 5000 but I've worked on about two dozen
5150's in the past two months. They definetly have a mini-PCI port
for the wireless available under the hatch beneath the laptop just
above the tiny modem card. Both aux and main antenna wires.
Dan
Reply to Dan
so if I just get a mini pci card for it, the antennae's are already in there?.......should I get it thru Dell or just anywhere else?
Cyndi
"Dan" <jasdfosd@asjedfoi.com> wrote in message news:1nahc1tsgegnpj5qo424up4p9ohg20o2fk@4ax.com...
> Dan
Reply to Anonymous
Cyndi--
As was mentioned earlier in this thread...the 5000 does NOT have a
built-in wireless antenna. It preceded the wireless explosion by
several years. I got mine in 1999,and I have to use a PCMCIA card with
an antenna in the card. It sticks out about an inch or so from the chassis.
HTH
Tom S.
Houston, TX
Reply to Anonymous
I Understand, but the post from Dan said the 5150's do have the antenna, and the 5150 is the one I have, not the 5000
Cyndi
"Tom Simchak" <tgsimchak@gmail.com> wrote in message news:kXbye.792$Ae.478@newssvr12.news.prodigy.com...
> Cyndi--
> HTH
> Tom S.
> Houston, TX
Reply to Anonymous
- 0 +
On Mon, 04 Jul 2005 13:28:15 GMT, "Cyndi" <noonehome@nowhere.com>
The mini-pci wireless in a 5150 should already have the antennae wires
waiting to be installed. They might be held down by some masking
tape.
I personally think a third party PCMCIA wireless card (linksys,
netgear, etc.) is less trouble, but you'll get better hardware and
software support through dell with a mini-PCI wireless card.
Dan
Reply to Dan
Thanks, Dan. I appreciate the information
Cyndi
"Dan" <jasdfosd@asjedfoi.com> wrote in message news:egljc19qkhfpj9epdjb7gs26elac9nv7vc@4ax.com...
> tape.
> Dan
Reply to Anonymous
Other than by removing the mini PCI wireless WLAN card and replacing it with
a wirelass WLAN card in the side slot, is there any way to add a external
antenna on this system? There appear to be two antenna cables connected to
the internal card ( one gray and one black). Is one of these capable of
being connected to an external jack (or antenna)?
Reply to Anonymous
There are 2299 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
What type of sound card does a dell dimentsion 8300 have
By Ubrales, 9 days ago:
Are the speakers turned OFF or disconnected? Check and make sure that the power adapter...
Best offers
