Help! ... System Has Decided to crash regularly
  • Graphics Cards
  • Pointer
  • Graphics
February 14, 2002 12:10:49 AM
System:
Windows XP and 2000
Athlon 1800+
Abit KR7A-RAID
Gainward GeForce3 64MB
2x WD400BB in RAID 0 configuration
512MB Crucial PC2100 cas2.5
SB Live! 5.1
3 COM 905B 10/100 ethernet card
My system was running completely fine until 4 days ago. I havn't really made any hardware changes, but my system decided to become unstable all the sudden. Several minutes after I log on, my mouse pointer stops. The mouse pointer doesn't move on the screen, but it still exists. I know this because I can still click on things wherever the mouse pointer would be if it were working (I just can't see the pointer).
Soon after this happens, I get a blue screen that says there was an error in nv4 or nv4_dsp (which is an nVidia display driver), Windows has shut down to prevent system damage. When windows restarts, the box in XP says that "Windows has recovered from a serious error caused by the GeForce3"
This problem has be at the end of my wits. I just replaced my motherboard once, and already its giving me problems. All suggestions are appreciated.
<P ID="edit"><FONT SIZE=-1><EM>Edited by gjkozick on 02/13/02 09:15 PM.</EM></FONT></P>
More about : system decided crash regularly
February 14, 2002 4:49:18 PM
Do you have installed the latest drivers from NVidia's site and did you install the latest Via 4-in-1 drivers?
My case has so many fans that it hovers above the ground :eek:  .
February 14, 2002 5:01:55 PM
The first thing I tried was updating drivers and BIOS. Everything is current.
February 14, 2002 5:15:40 PM
Then it could be too high temps or a too weak powersupply (atleast 300W).
Also check if you don't have any Resource Conflicts {ie. IRQ conflicts) and try with other mouse drivers, if you use the drivers supplied with your mouse then try the Windows default drivers.
