problems with screen resolution and how my monitor displays
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
ok..everything is working totally perfect but the only problem is that when
ever i start up any program or whatever, it doesn't show the ENTIRE page, it
cuts off some of the left side, and I tried fixing it by dragging the side
inward but it didn't work..so what can i do?
3 answers Last reply
More about problems screen resolution monitor displays
  1. Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
    right click an empty spot on the desktop /properties /settings
    what does it say???
    can you change it to More screen resolution??
    peterk
    Never trust a computer you can't throw out the window. - Steve Wozniak
    "rosad88" <rosad88@discussions.microsoft.com> wrote in message
    news:4DAF993C-4653-473C-AEB4-114961667544@microsoft.com...
    > when
    > it
  2. Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
    oh well it fixed on its own..surprisingly..but thanks so much for ur help..:)
    > what does it say???
    > peterk
    > > when
    > > it
  3. Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
    With the program window focused press <alt>, <left>, <enter>, <down>,
    <enter>, use the arrows to control the direction of the window so that
    it is in sight then press enter. Or instead of using the keyboard
    blindly make sure the window is focused then right click the item in
    the task bar and click move. Then use the arrow key to move it in sight.
Displays Screen Resolution Microsoft Monitors Windows XP
