Gaming speed with Wireless
Forum Wireless Networking : Wireless General Discussions - Gaming speed with Wireless
Archived from groups: alt.internet.wireless (More info?)
I have 3 computers in 1 home that I want to setup a wireless internet.
The Router is a Linksys WRT54G and I have 2of WMP54G USB for 2 of the
computers.
The main computer will be connected to the router by a cable and the other 2
computers, wireless.
Is this hardware and setup good enough for gaming between the 3 computers
and gaming all 3 through the internet ? Can I expect any lag at all from the
wireless connected machines ?
All 3 computers are very fast (P4 3 gig with 1 gig of dual channel memory).
If there is any better hardware for setting this up please advise me.
I am very new to wireless.
Thankyou
Ron
Sponsored Links
>computers.
>Thankyou
>Ron
It will be bad for FPS. All WiFi gear is currently half duplex only.
That is you can send data or receive data but not both at once. In a
first person shooter that spells sudden death. Meanwhile any $5 wired
nic is full duplex.
Reply to Anonymous
You may have a problem having nothing to do with wireless if you try to play
some Internet games on multiple computers simultaneously. The problem is
that with a NAT router, all your computers appear to have the same IP
address on the Internet. Unless the game software or the game server allow
you to specify the TCP or UDP port number, you won't be able to play over
the Internet with multiple computers. Diablo II has this problem. This
isn't a problem for LAN games though, since they only use the Ethernet
switch portion of the router, not the routing function.
Ron Bandes, CCNP, CTT+, etc.
"RonK" <nothere@home.com> wrote in message
news:jv4xc.15658$sS2.526644@news20.bellglobal.com...
> computers.
the
memory).
> Thankyou
> Ron
Reply to Anonymous
> >computers.
other 2
the
memory).
> >Thankyou
> >Ron
> nic is full duplex.
I have heard from someone here that if you hooked an Ethernet bridge to one
of the LAN ports on the router that one radio can be receiving while the
other is sending.
I have no experience with this, but it sounds reasonable.
Reply to Anonymous
- 0 +
To add to this in regards to internet gaming, you could also run into
severe lag if you have a very limited upload bandwidth - like around
256K or less.
Jago
Reply to jago
Thanks for all the replies.
My buddy wants to try the wireless so I'll post back here with the results.
The computer supplier said I can exchange the wireless hardware for wired if
I want within 7 days.
Thanks again
Ron
> computers.
> 2 computers, wireless.
> the wireless connected machines ?
> memory).
> Thankyou
> Ron
Reply to Anonymous
I should have listened to your suggestions better and convinced my friend to
go wired !
Very poor performance and even the signal strength was lousy on the computer
furthest from the router.(about 150 ft away)
Tomorrow it will be wired.
Thanks
Ron
> computers.
> memory).
> Thankyou
> Ron
Reply to Anonymous
100% success with wired.
Thanks again
Ron
> computers.
> memory).
> Thankyou
> Ron
Reply to Anonymous
Tom's Hardware > Forum > Wireless Networking > Wireless General Discussions > Gaming speed with Wireless
There are 936 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
