G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
When I use my new printer and camera a message comes up with use high speed
usb 2.0 port. But when I try to find this it says it is not on my windows xp
computer how do I upgrade to this what to I need to buy
C.R
G
Guest
Guest
Hi,
If your system does not have USB2 ports (only USB1.1), then you would need
to purchase a PCI add-on card for them. You need to check first that you
have an available PCI slot to install it in. There is no reason that you
have to do this though, as the devices will work on USB1.1, they will just
have a slower transfer speed.
Best of Luck,
Rick Rogers, aka "Nutcase" - Microsoft MVP
http://mvp.support.microsoft.com/
Associate Expert - WindowsXP Expert Zone
www.microsoft.com/windowsxp/expertzone
Windows help - www.rickrogers.org
"Carolred" <Carolred@discussions.microsoft.com> wrote in message
news:7BA744DC-9CF2-4FF6-95C5-A35802BE058E@microsoft.com...
> speed
> xp
> C.R
