Help Center and System Info not working
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
When I try to open either the Help Center or System Information I get a brief
hour glass cursor and then nothing happens. I went thru all of the
suggestions at Kelly's Korner Help and Support FAQ without results. The Help
Center service is running, but none of the Help processes are running though.
The paths for both seem to be correct. The index.dat file for msinfo32 is
present (I even replaced it with a known working one just in case). I virus
and spyware scanned. I tried an inplace Windows reinstall. What else would
cause both of these to not function at all?
1 answer Last reply
More about help center system info working
  1. Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
    For the Help and Support issue, here is a couple of options starting with a
    DLL registration. (Proceed to next method if one fails to resolve the
    problem):
    Type in Start, Run dialog:
    helpctr -regserver
    regsvr32 itss
    regsvr32 hhctrl.ocx
    regsvr32 jscript
    Fix Windows XP Help - from Doug's site:
    http://www.dougknox.com/xp/utils/fix_windows_xp_help.htm
    In _nothing_ helps, try reinstalling HelpCenter:
    Open %systemroot%\inf folder and locate the PCHealth.inf file (might show as
    PCHealth in W.Explorer). Right-click the file and choose "Install". Insert
    your XP CD when prompted. If you have a Service Pack installed, be sure to
    point to the %Windir%\i386\ServicePackFiles folder, or your slipstreamed XP
    CD (if available).
    Ramesh, Microsoft MVP
    Windows XP Shell/User
    http://windowsxp.mvps.org
    "Canines" <Canines@discussions.microsoft.com> wrote in message
    news:D0134EB8-AAE9-4CE6-B9A1-883E95B59266@microsoft.com...
    > brief
    > Help
    > though.
    > virus
Support Microsoft Windows XP
