Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
Hey everyone, I have some problems that started last night.
Okay, first problem is that NO programs open anymore. All the icons on
the Desktop fade when I doubleclick them. I can't select the program
from the Start menu, and the "Run" option won't open them either. When
ever I use "Run" to try opening something, I get this message:
"The file does not have a program associated with it for performing
this action. Create an association in the Folder Options control
panel."
Also, I should note that on the desktop, none of the icons show up and
all the shortcuts have a ".lnk" after them. My Computer and Control
Panel won't even open.
Second problem: I figured I could just do a System Restore to a day
earlier, but System Restore won't open! If I click it, it never comes
up. I tried it in Safe Mode, and still nothing. So, does anyone have an
idea what my problem is? Thanks in advance!
Hi,
If System Restore doesn't work from the command prompt I would suggest you start scanning
for virus/malware infection.
Virus and Spyware removal and prevention
http://bertk.mvps.org/html/spyware.html
> night.
> the icons on the Desktop fade when I doubleclick them. I
> can't select the program from the Start menu, and the
> "Run" option won't open them either. When ever I use
> performing this action. Create an association in the
> Folder Options control panel."
> icons show up and all the shortcuts have a ".lnk" after
> them. My Computer and Control Panel won't even open.
> Restore to a day earlier, but System Restore won't open!
> If I click it, it never comes up. I tried it in Safe
> Mode, and still nothing. So, does anyone have an idea
