Programs won't work, and neither will System Restore!
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
Bert Kinney Wrote:
> Hi,
> If System Restore doesn't work from the command prompt I would suggest
> you start scanning
> for virus/malware infection.
> Virus and Spyware removal and prevention
> http://bertk.mvps.org/html/spyware.html
> Here are some Windows XP File Association Fixes you may find helpful.
> http://www.dougknox.com/xp/file_assoc.htm
> Regards,
> Bert Kinney MS-MVP Shell/User
> Unforunately, none of the REG files work. I've tried every way I can
> think of, but, just like everything else, they refuse to open.
> Also, the command prompt method didn't work. For whatever reason,
> "C:/WINDOWS" is not an appropriate command according to my computer.
Sgt Keroro
G
Guest
Guest
It appears that there is an error that is propagating itself all over
the place. In spite of the many references to RSTUI.EXE, it looks like
the correct command is RSTRUI.EXE. I copied the erronaeous name from
another post. My apologies.
We judge others by our own limitations.
G
Guest
Guest
I should have picked up on that also.
Glad to see you have it working now.
Regards,
> itself all over the place. In spite of the many
> references to RSTUI.EXE, it looks like the correct
