Here's my system:
P3 733 MHz
256 MB RAM
SB Live Value
Tyan Trinity 400 Motherboard (VIA with latest 4 in 1)
Geforce 2 Pro (using latest Nvidia drivers)
1. I recently posted that I was getting a slowdown in Dungeon Siege, however poor performance in Direct 3D has happened in othe D3D games including Thief
and Halflife (yes I know Open GL would probably work better in the latter). In Thief and HL I would get this brief pause after every 5th or 7 th step. The framerates until this pause would be fine. A similar problem occurs in
Dungeon Siege, where about every 10 th step there's a slight slowdown, sometimes not as often. In DS the slowdown is most noticable amongst the
scenery, while the character animations tend to be smooth. I will say the pause does not occur with an access of the hard drive. Now I can understand
that with my lower end system I may not get optimal performance out of DS,
but with this system I would think Thief and HL would run with no problems. How can I improve my D3D performance?
Here's what I've tried:
Updating to DirectX 8.1
Installing the latest Nvidia drivers
Installing latest 4 in 1 drivers
Turning off AGP 4x in BIOS
Verified Video BIOS shadow was disabled in the BIOS
2. I can't afford a Mobo/CPU upgrade until later. What sort of upgrade would help? I was thinking about getting a Pentium 3 1064 MHz, as that's the fastest my current board could handle, I assume the extra horsepower
would show some improvement.
TIA,
Brandt
P3 733 MHz
256 MB RAM
SB Live Value
TIA,
Brandt
