G
Guest
Guest
ok I have this strange problem with my computer, when I use certain resolutions such as 1280 x 960, 1152 x 864 for example on my desktop the screen gets weird and stretchy, it becomes sort of oval and parts are off of the screen, sort of uhh bubbly........so I use 1280 x 1024 and everything is fine........but in games like half life for instance when I use 800 x 600 or even on Baldurs Gate 2 now its oval and weirdly shaped, screen is stretched the top and bottom corners are poined inward, not sure if I explained this right by its very weird and not sure how to fix !!!!!
I have
Athlon XP 1900
ASUS 415-D Nforce motherboard
Geforce 4 ti4600 128 ram 3-d card (newest drivers)
Soundblaster Audigy
Lite on 24x10x40x
Lian Li PC65 aluminum case
Windows XP Professional
thanks
I have
Athlon XP 1900
Soundblaster Audigy
Lite on 24x10x40x
thanks
