G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
Hi, any help on this would me much appreciated….
Running windows XP Pro, P4 3.2ghz, 1024mb ram, Maxtor 80gb SATA HD.
Everything seemed to be fine when I received first ever crash on system,
blue screen stop error. System auto restarted and soon after logging on
blue screen stop error repeated (this happened around 8 times). Thought
best to do a replace install of the OS via boot from CD as I was not
able to get the system to run for more than a few minutes without the
fatal error re-occurring. Had an error message during re-install to say
that setup had performed maintenance on the hard disk and would restart,
ok, restarted and continued setup until about 90% way through copying
files for installation I had repeated errors of files not copying
correctly with prompts to retry, skip or cancel. After retrying multiple
times I decided to skip the problem files (12 or so dll files) and see
if the install would be successful which it wasn’t. Attempted re-install
again and again, same problems.
I now have a system that will not start and refuses to re-install the
OS, decided to try a clean install on a new replacement hard drive
(after managing to rescue my files by hooking up the HD to another
system) still having the same problem, files will not copy on setup for
the installation, even tried an old copy of windows ME just in case my
XP pro cd was faulty but still cannot get through installation without
errors and failures! I haven't a clue what to do next....
Again, I would be grateful for any help
Many thanks
chris
Many thanks
chris
