win 98 display problem
Forum Windows 95/98/ME : Windows 95/98/Me General Discussion - win 98 display problem
display won't stay at any other setting but 800X600 for more than a few reboots. Have set it in display and nvidea control panels and it will not stay.
Sponsored Links
what version nvidia drivers are you using, and with which video card? did you make any changes to your hardware or software just before this started?
Reply to Boilermaker
Thanks, The card is a geoforceMX400 and the driver version is 3.0. I haven't made any changes to any software since installing the card. This was a newly built computer with onboard sound and video before cthia installation.
Reply to bandit1416
Did you disable the onboard video? That could be messing with the new card. You should be able to disable it in the bios. If not then disable it under the device manager.
Had to do this on my friends dell computer. Been working fine.
Reply to sturm
Tom's Hardware > Forum > Windows 95/98/ME > Windows 95/98/Me General Discussion > win 98 display problem
There are 403 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
