Archived from groups: alt.internet.wireless (More info?)
Hi all,
I'm trying to connect my Dell Axim X30 to my wireless network.
The dell has an integrated wireless card.
I'm using Windows mobile 2003 on my handheld.
Windows XP on the desktop and am using a Microsoft wireless base station
(Model Number MN-700) as an access point with the most current version
firmware. The access point is using DHCP and am connecting the computers
via mac filtering.
I'm able to see the access point on the handheld computer and can even
connect to it but am unable to connect to the internet.
I'm using time warner cable internet as my ISP. I have DHCP set on my
pda as well.
I should let you know that I have successfully wirelessly connected a
desktop to my wireless network.
I'd appreciate any feedback.
Thanks
maddog
jerry wrote:
> Hi all,
> via mac filtering.
> pda as well.
> Thanks
> maddog
I found out what the problem was.
I had my routers wireless mode in g performance, once i changed it to
mixed b compatible. I was able to connect. I can connect wirelessly from
6 floors down in my apartment building.
