Archived from groups: alt.internet.wireless (More info?)
I finally got my wireless network up & running by calling D-Link's
tech support--they got my DI-524 router up & running. The PC upstairs
is connecting via a D-Link DWL-G510 card.
Right now I'm just using the default settings--how do I make my
wireless network more secure? Both PCs have software firewalls
installed & up-to-date anti-virus software.
Can you guys direct me to a website with easy to understand guides on
wireless network security? Thanks.
Kim/Dreamspinner3
Visit My Homepage: http://members.tripod.com/dreamspinner3/
"Dreamspinner3" <dreamspinner3@softhome.net> wrote in message
news:04dnc09ag8qri2ce7ijqrah33b6610gjti@4ax.com...
> Kim/Dreamspinner3
Dink have some reasonable guides on securing their devices, usually found in
the tech support section specific to the device.
WEP 128 strength
Mac authentication and
suppress ssid transmit is a good start
anything over and above this is getting specialised, such as vpn
If you're running a home network, I would start with the following changes:
SSID - change to some new name-oddball mixture of alpha/numeric on both
router and computer. After change is made and network reestablished, stop
broadcasting the SSID (casual passersby won't know the network is there)
Enable WEP (64 bit slows down the network less than 128 bit). On the router
set up page, input a 10 digit hex code (make one up with any combo of alpha
numeric with the alpha restricted to a-f and numeric 0-9). Put them in
both the router and computer. Network will be lost until they are inserted
on both sides.
That's generally enough for most home situations. You could go further in
restricting access to particular MAC addresses (namely the MAC address of
your laptop).
A dedicated hacker could still access your network, but doing the above will
deter the neighbours and casual passersby.
"lowlystudent" <lowlystudent@hotmail.com> wrote in message
news:40cbdcb2@quokka.wn.com.au...
> > Kim/Dreamspinner3
> > Visit My Homepage: http://members.tripod.com/dreamspinner3/ >
in
> WEP 128 strength
> have fun >
I'm not sure how to do this part. I successfully did the other things
you explained.
On Sun, 13 Jun 2004 08:11:47 -0400, "Alan White"
