Yes No
Ads
Tom's Hardware > Forum > Windows 7 > Security > [Solved] Auto Run Doesn't Work!!!!
Forum Windows 7 : Security [Solved] Auto Run Doesn't Work!!!!
Best answer from anonymous1.
When I mount images through Power ISO nothing happens and every damn time I gotta go to my computer and click the damn thing, so annoying!
I had serious problems with viruses and spyware so I used Combofix which broke my daemon tools so I decided to get powerISO. One of programs I used asked me to disable autorun it could be combo fix that asked me I cant remember and I selected yes expecting that it would simply disable it in control panel... Is there any method I haven`t tried to make autorun work?
Ive tried everything...
Changing settings in PowerISO
changing settings in Control panel, after some research I even got down to checking registry which was also set right but it still doesnt work I also enabled GodMode and went through everything in there...
Reply to Andreyftw
Win7 comes with a built in iso image burner btw.
Go to Control Panel\Hardware and Sound\AutoPlay
Enable or disable
save
Do yourself a favor and download MSE and Malwarebytes.
I've been running 7 for 6 months without a hiccup.
Message quoted 1 times
Message edited by davcon on 07-27-2010 at 01:34:23 AM
Reply to davcon
Enable or disable
save
Yes I know but I dont need to burn the image I need to open it...
Didnt you read what I wrote? I said ive done the control panel tweaking obvously that was my first step
and I was on spybot it found viruses but couldnt remove them
Reply to Andreyftw
I suggest you run Malwarebytes in safemode.
Reply to davcon
Thats not my problem now! The problem is that the damn autorun doesnt work the viruses are gone combofix killed em all
Reply to Andreyftw
Hey Andreyftw Lets all be nice to the good people trying to help you out.
Reply to anonymous1
OK...sorry, Ill be nice hope I didnt hurt any1 feelings...
So umm good people any real help so far?
Reply to Andreyftw
Best answer
How To Enable/Disable Autorun (Windows XP)
1.Open Windows Explorer by pressing the Windows + "e" key.
2.Right-click the desired CD-ROM and select Properties from the menu.
3.Select the AutoPlay tab.
4.Select each item from the pulldown list and for the Action to perform, select "Take no action" to disable autorun, or pick the apporpriate action to take if enabling autorun.
5.Select OK.
Are you running xp?
Reply to anonymous1
What's with people lately? They act like we're getting paid. :heink: I say let them suffer... :lol:
------------------------------ What if everything is an illusion and nothing exists? In that case, I definitely overpaid for my carpet.
Reply to w0lfattack
5.Select OK.
Are you running xp?
Nope I got w7 it doesnt have such tab =\
What do you mean? Are you saying that every1 should just be grateful for something somebody came up with without even thinking about it? I mean I was seriously considering that Davcon was actually messing with me and really, I havent said anything mean until I was told to be nice >_>
ps. Lets not go offtopic again if you aint got anything useful to say walkaway.
k Thx
Reply to Andreyftw
1. Go to Control Panel\Hardware and Sound\AutoPlay.
At the top, check Use Autoplay for all devices and Click Save.
Reply to anonymous1
Yeah thx. everything in a controll panel and registry has been changed but autoplay still doesnt work I need some not standard solution if such exists
Reply to Andreyftw
There are 2310 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
MASHITA DVD-RAM UJ890t driver
By Brett928S2, 18 hours ago:
Hi :) 7 has the driver for it....are you asking about software ? All the best Brett...
Best offers
Top experts
