G
Guest
Guest
P4T533-C & Geforce4 I/O conflict XP
This is an error I'm getting under the resources for the video card:
Input/Output Range 03B0 - 03BB used by:
Intel(R) 82850/82860 Processor to AGP Controller - 2532
Input/Output Range 03C0 - 03DF used by:
Memory Range 000A0000 - 000BFFFF used by:
I can't change anything in the properties for the videocard of the AGP controller. I called Gainward and they are referring me to Asus. I called ASus and they have opened a support incident because they don't know what's going on.
I've installed the inf drivers for the chipset from intel and nothing's changed. When I install the drivers for the video card, it works fine until I click ok when I'm done installing the drivers, then the screen just gets random characters everwhere and I have to re-boot using last known good configuration. I'm using Widnows XP as well.
I've tried the beta bios drivers for the board, and that didn't change anything. the board came w/ 1003 bios, so I tried 1002 and 1003 beta 02 nothing helped.
I'm using the onboard audio and nic card, nothing else is plugged into the other pci cards. 512 MB of PC800 memory is installed as well.
Any ideas?
Thanks
Any ideas?
Thanks
