Tv out problems HELP!!!
tkialmighty
Hey all, hoping someone might have some ideas. I got a problem that I am sure is fairly simple. I just got these RF (radio frequency) Audio/Video transmitters and I hooked the sender to my Geforce 1 256 DDR graphics card by s-video cable-s video/rca video adapter-rca video. That then transmits to the tv by RF... All that doesn't really matter. The problem I'm getting is that on my tv (32" Sony Wega) there appears vertical black bars surrounding the video area. I read up and all I could find is that maybe my tv settings were set to extremes, but I couldn't even find any way to adjust the height/width of the display. I set my monitor at 640x480 and 800x600 and it looked exactly the same on the tv. Anyone have any suggestions as to getting the tv to fill up with the video output from the computer?
Thanks a million.
-A
noko
2,414
Get TVtool which will allow you to adjust your overscan area. Nvidia drivers does not address this at all. You will have to fork out some bucks and the program isn't perfect but that is the best I found so far for a Nvidia card. ATI does it hell alot better I will add. My GF3 Ti200 800x600 output through the SVHS doesn't work to good either. Here is the link:
<A HREF="http://tvtool.info/index_e.htm" target="_new">http://tvtool.info/index_e.htm</A>
