try to copy that file from another operating system... same os your using... and also note where it's located... then copy that file to that location on your os... see if it helps.
doesnt sound like a windows xp file......stop it from loading in the msconfig and see if any applications stop working.....my guess is not since it doesnt seem to be working now anyways.
If you dont know how to use msconfig....get back to me and I'll elaborate.
EC
<font color=red> Quantum Computers! - very interesting </font color=red>
The program dwwin.exe is Dr Watson - a Windows debugging tool. You can get more info by typing drwtsn32.exe in Start - Run. Click on the Help tab. To turn off the Dr Watson debugger, apply the following Windows NT / Windows 2000 / Windows XP registry hack:
To re-enable Dr Watson, you can change Auto back to 1 or from the command line type drwtsn -i.
It is likely though that your system is trying to throw a stop error. Look in Control Panel, Event Viewer, in the System log entries to see if a critical stop error has been generated.
