So, here is the situation: i've bought today a fresh new MSI GeForce 4 64MB DDR Ti42000, to make a set along with this (relevant) hardware:
- AMD Thunderbird 1.4
- Asus A7v133 (KT133A)
- 384 SDR RAM
- Nokia 447 17" Pro
I've installed everything correctly, as it was supposed to , and the performance was not closer to what a GeForce would do. Initially i tested only with Unreal Tournament, and it was odd, because i had lost of frames (150-200) but suddenly in the middle of the action it was dropping to 50/60, which is very very low for this video card. Imediatly after i've tried a large set of drivers, from 29.80 to 29.42 and not forgeting the originals that came with the card, 27.20, all unsucessful. According to friend's opinion, which have GeForce 3, they don't even go below 90fps, and are using settings more heavy to the GPU and CPU than mine.
I suppose and hope, there is a know bug about compatibility with KT133A and GeForce 4?
Thankss in advance. Even the smallest post may help! Please, its pissing me off
Best Regards,
Mário Lopes
- 384 SDR RAM
- Nokia 447 17" Pro
Best Regards,
Mário Lopes
