Tom's Hardware > Forum > Wireless Networking > Wireless General Discussions > Senao/Engenius 3054cb3 long range AP/Bridge Help!
Forum Wireless Networking : Wireless General Discussions - Senao/Engenius 3054cb3 long range AP/Bridge Help!
Archived from groups: alt.internet.wireless (More info?)
I own a 3054CB3 Long Range AP/Bridge, firmware version 2.2.0. It's
running in AP mode and currently I'm unable to make a 802.11g
connection with it. I see the wireless network, connect to it, recieve
and IP, and then lose the connection. It cycles like this indefintely.
I've tried 802.11g only max performance and 802.11g standard mode are
the same results. I've tried 802.11b only as well as 802.11g/b mixed
mode, but nothing allows a 802.11g or 802.11b card to connect to it.
I've tried a Belkin 802.11b, a Compaq WL2000 802.11b, a USR 802.11g
card, and a Netgear WG311 v2 802.11g. Prior to my firmware upgrade I
was able to get a connection using Mix mode with the 802.11g cards,
the 802.11b cards would connect but give me an invalid IP address.
DHCP is disabled as a client and as a server (set to a static address
with a router/firewall serving DHCP which worked prior to firmware
upgrade). WEP/WPA is not enabled. PSM mode IS enabled. (all other
advanced wireless settings are default)
It is accessible from a wired connection. I've tried different
channels, reloading the firmware, reseting to defaults and rebuilding
settings, using the built in reset button and rebuiltin, multiple
modes, multiple methods of reseting the device in various orders (web
reboot, hard power off with time and without time, both at various
intervels, etc)
different client adapter cards and various distance s doesn't seem to
affect it. I have an senao/engenius NL-3054cb Aries 802.11g PCMCIA
card enroute to me, but I'm guessing the same results.
I'd like further lines of pursue and futher assistance on this
problem. I'm also curious if anyone has Senao/Engenius's tech support
number. I'd like to hash this out with them if I can get a hold of a
real person.
Sponsored Links
There are 1153 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
