Archived from groups: alt.games.diablo2 (
More info?)
"~misfit~" <misfit61nz@hooya.co.nz> wrote in message
news:33bnnmF3s4bdbU1@individual.net...
> EB wrote:
>> "Nomersu" <nomersu@gmail.com> wrote in message
>> news:1104139321.666385.216630@z14g2000cwz.googlegroups.com...
>>> EB wrote:
>>>> I've created a poison necro. Problem is Poison nova is such a mana
>>>> hog. How does anyone get around the mana drain problem. I have
>>>> socketed armor with 4 pskull in it for great regen. I also thought
>>>> about having skulls in a dagger (using poison dagger also) What
>>>> would anyone else suggest?
>>>> EB
>>> How about 4 perfect sapphires in armour and 3 in helmet like mask.
>>> Should give you 7x38=266 to mana. Mana regenerating items are not so
>>> good if you have only small amount of mana. I have starting gear
>>> that I use for all my casters: 3 perfect sapphires in breast plate,
>>> 3 in mask. Str needed 30 on level 18. For younger characters I use
>>> less perfect sapphires in similar equipment.
>>> -Nomersu
>> Good idea. didn't think of that. That, with mana regen rings, should
>> work great.
> How about an Act II merc with the runeword "Insight"?
> ~misfit~
Already in progress. Problem is I'm still in Normal, but will venture out
into NM when i'm about level 50.
Any suggestion on the type of Act 2 merc? Normally I would use a Thorns merc
for my Necros, but since I'm not using minions (other than a fire golem),
maybe the freeze merc?
EB
