I am using the VisionTek Xtasy Geforce 3 Ti500, and have noticed a bit of a problem. I noticed it today while inspecting my computer to find the 3 pin connector for the case fan. The fan on the card will intermittently slow down quite noticeably. I was told by a friend that this was not supposed to happen. It happened a couple times when I started up the system, and sometimes it ran fine. I noticed it once before on my older computer. Is this normal, or is it a problem with the card? If anyone has seen or heard anything about this kind of thing happening please let me know...I am a little concerned...a few of my games, notably Morrowind, MaxPayne, and Warcraft III seem to randomly freeze up, and I am wondering if perhaps the card's fan is cutting out and causing an overheat that leads to the lock up.
Any help will be greatly appreciated...system info is as follows:
AMD Athlon XP 1800+
ECS L7VMM Motherboard
512MB PC2100 DDR RAM
Soundblaster PCI 512
Geforce 3 Ti500
Maxtor 80gig Hard Drive
AMD Athlon XP 1800+
Geforce 3 Ti500
