H howyrd Distinguished Jul 29, 2010 2 0 18,510 Jul 29, 2010 #1 Hello, Attempting to use my Dazzle dvc90 with Win7 and can only get video. Any solutions out there? Thanks
bmathews Distinguished May 21, 2010 301 0 18,810 Jul 30, 2010 #2 Have you tried using the Vista drivers? That usually works fine. Try here: http://forums.support.roxio.com/index.ph… I hope this helps! Brett M, Windows Outreach Team Upvote 0 Downvote
H howyrd Distinguished Jul 29, 2010 2 0 18,510 Aug 5, 2010 #3 bmathews : Have you tried using the Vista drivers? That usually works fine. Try here: http://forums.support.roxio.com/index.ph… I hope this helps! Brett M, Windows Outreach Team Thanks for replying. The link you quoted seems to be broken; however, I'll take your suggestion and look for some Vista drivers elsewhere. H. Upvote 0 Downvote
cassandraf_winteam Distinguished Apr 16, 2010 509 0 19,060 Aug 5, 2010 #4 Hi howyrd, I think Brett was trying to link you to this resource - http://forums.support.roxio.com/topic/17465-dazzle-dvc90-vista-drivers/ Cheers, Cassandra Microsoft Windows Outeach Upvote 0 Downvote
