I really need help weighing my options here. I'm looking to purchase a system within the next 2 weeks and I'm deciding between the ATI 9700 Pro and the Nvidia GF4 Ti4600. Here are some of the advantages and disadvantages I've come up with so far. Feel free to add or comment on them.
ATI 9700 Pro:
Advantages:
- Awesome performance (Outperforms Geforce 4 Ti4600 in almost everything)
- DirectX 9 Support
- Max settings for games are playable (FSAA...etc)
- Industry-leading graphics quality
- Next Gen DX9 games will be supported on this card
Disadvantages:
- High Cost ($50 to $100 more CDN)
- Functionality dependant on BIOS revision (1.01 vs 1.03)
- ATI Catalyst drivers still perceived to be unstable
- May require purchase of another power supply
- May need to make several BIOS and software tweaks & updates to play games/increase stability
- R300 chip is still very new and bugs are still being worked out
Nvidia Geforce Ti4600
Advantages:
- Detonator drivers are usually very good and stable
- Much faster than my current card (AIW Radeon 32mb)
- Reputation and quality of Nvidia's products
- Able to run all of today's games with little chance of instability
- No need for extra power
- Slightly cheaper than 9700Pro
- Has been out longer than 9700Pro and so most bugs have been worked out
Disadvantages:
- Doesn't perform as well as 9700Pro
- Image quality is believed to be not as good as ATI's products
- No DirectX 9 support (May have to purchase a new card within a year to play DX9 games)
The system I'm looking to purchase is the following:
Intel P4 2.53Ghz
Asus P4PE i845PE
Kingston 512Mb PC2700 DDR Ram
Enermax 450 Watt Power Supply
(With little to no overclocking being done)
I've been surfing forums and I've been seeing a lot of issues with 9700Pro's stability. With the GF4 I haven't seen quite as much though. Most issues with GF4 that I've seen only deal with decreased performance between driver updates. Right now I think I'm leaning more towards the GF4 because at the moment, I'm more concerned with stability than performance. What good is a powerful video card if it crashes lots or needs to have its BIOS tweaked somehow? But I'm really considering the 9700Pro... I guess that's why I'm posting here, I really just need some convincing from you guys. Any thoughts???? Maybe you can share some of your experiences with either card??
ATI 9700 Pro:
Advantages:
- DirectX 9 Support
Disadvantages:
Advantages:
Disadvantages:
Intel P4 2.53Ghz
Asus P4PE i845PE
