I have two computers connected through a router/firewall to my cable modem. One is running XP Pro, the other is XP Home. They both work fine when they connect to the internet, but for some reason I can't share files between them, or even ping each other. They are both part of the same "workgroup". The directory I want shared is marked as a share. The software firewall feature is disabled on both machines.
I went through endless microsoft bs help and finally ended up running the network setup wizard. What a mistake that was, it created some network bridges on each machine. I finally got my lan connections unbridged. But the problem still isn't solved and I now have a new problem. The new problem is that on the XP Pro system, whenever I fire up IE, it will prompt me to "connect" or "work offline" the first time I access a web page, and I have to press connect to get past the problem (sometimes have to do that multiple times).
It's got to be possible to do what I want, and it's got to be possible to get IE to come up without the stupid dialog box (it worked fine before I started doing all this bs). Help!
