News
Sony rolls out new Vaio line in Japan
Sony has rolled out several one piece computers that are designed to be used as media computers. The new Vaio L computers combine the main hardware and monitor into one package, similar to Sony's Vaio W computers and Apple's older iMacs. Read more
Sony announces digital camera with touch-screen focusing
Sony preps a new tweak for its Cybershot digital still camera series. The DSC-N1 comes with a "Free Spot Focus," which lets users focus on objects with a simple tap on the LCD screen. The camera will also integrate enough internal memory to house a photo album with up to 500 pictures. Read more
Coming soon to a monitor near you: LEDs
After years of development, the first LCD displays using Light Emitting Diode (LED) backlights are about to enter the market. Initial product offerings will be few and far between, but much of the industry will be watching from the sidelines, gauging the market reaction and weighing the pros and cons of jumping into the game, market research firm iSuppli expects. Read more
Analysis: Sony BMG copy protection may be stealthy, but is it a "rootkit?"
A noted security software engineer learned that a well-used copy protection scheme employed by Sony BMG on its audio CDs, uses stealth protection techniques to evade user detection. Maybe that's bad, but how bad is it, really? Read more
Latest Reviews & Articles
Life At 2 GT/s: 6 GB DDR3-2000 Memory Kits Compared
Memory vendors put a lot of effort into drumming up excitement over high-end memory kits, but many of those products turn out to be vaporware. We test six DDR3-2000 kits that enthusiasts can actually buy today, and push them as far as they'll go. Read more
DDR3 Memory Scaling On AMD's Phenom II X4
DDR3 memory is available in speeds ranging from DDR3-800 to DDR3-2133. Which is the best memory choice for AMD’s Phenom II X4? We tested as many speeds as possible using aggressive and conservative timings to find the sweet spot for your next build. Read more
Intel Core i7-975 Extreme And i7-950 Reviewed
Today Intel launches two high-end processors that take the place of its i7-965 and i7-940 CPUs. More speed? Same price points? We’ll take it! But are the new chips compelling enough to warrant spending more than you would on an i7-920? Read more
AMD Athlon II X2 / Phenom II X2 And Low-Power CPU Bonanza
Eager to let you know it’s been busy, AMD is launching four new processors today: the first Athlon II, a dual-core Phenom II, and two low-power 65W Phenom IIs. We bought ourselves a new Pentium E6300 and let loose with AMD’s latest. Read more
All the Reviews & Articles
sony monitor
CPU (1) Intel Pentium III@803 MHz
Video Board NVIDIA GeForce2 GTS/GeForce2 Pro
Video Mode 1920x1200@16bits/pixel
RAM 128 MB
OS Windows 98 4.10.2222 A
Area Tested Value
CPU Integer 2332.439 MIPS
CPU Floating Point 924.4721 MFLOPS
Video(2D) 119.0995 MPixels/s
Direct3D 383.1023 MPixels/s
OpenGL 17.19941 MPixels/s
Memory 1644.178 MB/s
Cached Disk 147.1989 MB/s
Uncached Disk 4.323905 MB/s
Is this normal ? I'm talking about the refresh rate. I have a sony GDM 17SE-1 when i tell windows i have thi monitor i only get options up too 1280x1024 when i knew from reading this was wrong . it should doo 1600x1200. ok soo good i delete my monitor, refresh , and windows install a default monitor. I can now choose many settings !!!so lets try them all > can you believe this 1920x1200 only two opps. above this this is a wintune score to see a result 3d mark only reported 1024x768
Tom's Hardware > Forum > Computer Peripherals > CRT Monitors > sony monitor
There are 823 identified and unidentified users. To see the list of identified users, Click here.
You are about to answer a thread that has been inactive for more than 6 months. If you still wish to proceed, please ensure that your posting is original and does not duplicate or overlap any prior responses to this thread. Add a reply Cancel
Sponsored links
