Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Can't get audio connection to work with MSN 6.2
Forum Windows XP : Windows XP General Discussion - Can't get audio connection to work with MSN 6.2
Archived from groups: microsoft.public.windowsxp.messenger (More info?)
Hi,
We are using a Linksys router WRTs4g (wireless although
this is the main computer) and have an earthlink
connection through SPRINT (DSL) here in Vegas. For some
reason we can not get the audio connection to work. Any
suggestions?
Sponsored Links
Greetings Rags,
Firstly, make sure you have the latest firmware for the router from here:
http://www.linksys.com/download
If you've already done that, then make sure that you have Universal Plug and Play (UPnP)
enabled in the router configuration. If you had to turn on UPnP, reboot, and then try again.
____________________________________________
Jonathan Kay
Microsoft MVP - Windows Messenger/MSN Messenger
Associate Expert
http://www.microsoft.com/windowsxp/expertzone/
Messenger Resources - http://messenger.jonathankay.com
All posts unless otherwise specified are (c) 2004 Jonathan Kay.
You *must* contact me for redistribution rights.
"Rags" <anonymous@discussions.microsoft.com> wrote in message
news:197a01c49e73$e35e1d00$a501280a@phx.gbl...
> Hi,
> suggestions?
Reply to Anonymous
Most likely you are behind a firewall and using some kind of NAT. If so,
I highly recommend RealTunnel from Paradial (www.realtunnel.com). I was
having the same problem and decided to download their free IP tunneling
sw-worked like a charm !
I also suggest you read their demo.
Cheers,
AA
Rags wrote:
> *Hi,
> suggestions? *
lunaticfri11
Posted via http://www.mcse.ms
View this thread: http://www.mcse.ms/message1075889.html
Reply to Anonymous
There are 728 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
