Hello;
I have a computer which reboots itself at odd intervals, (usually when I am putting a strain on it). I beleive the reboots are caused by a drop in the 12 volt line to just over 6 volts. I have upgraded motherboard, CPU, memory, Case and Power Supply. Now this machine has all new components except for hard drives and video card ATI Xpert 2000. The weird thing is that the problem with low voltage is still there. So I now suspect that the ATI card may be the culprit.
Any thoughts anyone.
System config
ECS K7S5A Mainboard
AMD Athlon XP 2000
256 MB DRAM
ATI Xpert2000
300 Watt power supply
80 Gig and 30 Gig Hard Drives
40X CD
8X CDRW
Thanks in Advance
System config
ECS K7S5A Mainboard
AMD Athlon XP 2000
256 MB DRAM
ATI Xpert2000
40X CD
8X CDRW
Thanks in Advance
