I'm building a computer and I put in a ATI Radeon 9000 card (made by Powercolor, I believe), and it doesn't work. When I turn the computer on, the monitor will turn on, the computer will beep once, and then the monitor will turn off. I plugged in a PCI graphics card, and everything worked fine. I went into the BIOS and changed the primary graphics adapter from PCI to AGP, the AGP speed to 4x, and the aperture size to 64MB (which is the size of the card). I then took out the PCI, put in the AGP, and I had the exact same problem. I have a MSI-KT4V motherboard, which has the VIA KT400 chipset. My processor is the 2100+... Is the graphics card defective or do I need to change a setting?
Thanks for your help!
- Griffin
- Griffin
