Archived from groups: alt.internet.wireless (More info?)
Hi,
I am running a laptop with Windows XP Home and an AT&T Wireless
Router. The adaptor card is a Broadcomm.
The problem I am having if I exit out of Windows with the Wireless
connection enabled and then reboot the Laptop, I don't pickup an I.p
address from the At&T router. I get the default ip address from XP.
If I disable the wireless connection and then enable it , I usually
pickup the ip address (192.xxx.xx) and I could then hook up to the
internet.
If I disable the connection and then exit windows, I could then reboot
and when it is finished rebooting I can enable the wireless card and I
usually connect on the first shot.
I have the newest drivers on the Broadcomm card and the router's
firmware has been updated.
Also, I go over my brother's house and he is running a Linksys
wireless router and I don't have any problems. I connect each time
regardless if I boot up with an enabled connection or disabled.
On Thu, 01 Jul 2004 19:03:52 GMT, dan@hotmail.com wrote:
>Hi,
>internet.
>Any suggestions?
1. Turn off the Windoze firewall protection. If that turns into a
problem, get the free version of ZoneAlarm instead.
2. Remove the "network bridge" from the Control Panel -> Network
window. Unless you have a USB network, you don't need it.
3. Disable "802.1x authentication". That tend to mess up reconnects
and might have an effect on initial connects.
4. Try a fixed IP address, gateway, and DNS servers. It's not a
great idea to leave it that way if your laptop is going to be used at
hot spots but it will check if there is something else going on.
# Jeff Liebermann 150 Felker St #D Santa Cruz CA 95060
# 831.336.2558 voice http://www.LearnByDestroying.com # jeffl@comix.santa-cruz.ca.us
# 831.421.6491 digital_pager jeffl@cruzio.com AE6KS
