G
Guest
Guest
i am planning to get a new system but i cant decide on which processor to go with. the xp 1700+ is $169 at the local store (im reluctant to buy online since i seem to have bad luck when it comes to faluty computer products, dont wanna go through the rma hassle) anyways, the 1800+ is $215, from reading the posts on this board, it seems to be that the athlon xp is a good overclocker. so should i get the 1700+ and overclock it? and what kind of speed increase should i expect, im planning to use just a 20 dollar heatsink/fan, but i'll have at least 3 case fans in the case and i'll be replacing my case too since my old one is only 250 watts, is 350w necessary? or can i get away with a name brand 300w case/power supply.
i will be running 2 hds, a dvd and a cdrw.
the current 250w is running fine with those items and a p3 600 with a katmai core.
also i havent decided on which mb to get, the ones that im considering are:
asus a7v266-e
abit kr7a
MSI K7T266 Pro2
Epox EP-8KHA+(don't know the difference between the plus and the regular one)
my budget is about 500 bucks for the processor, mb, case and a stick of 256 ddr ram plus some accessories like cpu fans.
thanks in advance and have a happy new year
asus a7v266-e
abit kr7a
MSI K7T266 Pro2
