Archived from groups: alt.games.civ3 (
More info?)
Most of the cheats are obsolete. (Removed in a patch)
As to the best civ, as you poll enough people, you'll even find a
supporter for England in Vanilla.
Basically, some people looked at UU only, others look at traights only.
(Obviously, this makes a much difference for America.)
And how useful expansionsic traight (and weather or not it's better in
Conquests than Vanilla) is also a matter of controversity. The
seafaring traight in Conquests also has a similar level of
controversity.
Personally I think traights matter more than UU, but the UU should also
be considered. But also, thought should go into how that UU is meant to
be used rather than just dissing the ones that aren't intended for
direct attacks.
So, under Vanilla / PTW, I'd say the Industrious civs have a huge edge
over the non-industrious civs. And also Religious is a close second, so
that would make Egypt the best. (Now there are people who can't stand
the Egyptain UU, but I say that the intended use of the WC is to build
Knights faster. [As WCs and upgrade])
Under Conquests, the Agricultural civs have a huge edge over the
non-agricultural civs. So much so, that I avoid playing the Agricultal
civs in SP games.
