Archived from groups: comp.sys.laptops,alt.sys.pc-clone.dell,alt.os.windows-xp (More info?)
Every time I try to load XP on my laptop it gets to the point that only 35
minutes remaining then freezes up. The hard drive was reformatted every
time I tried to load XP. Machine specs are: PIII-700, 256MB RAM, 30GIG HDD.
CDROM is external made for the laptop-not PCMIA or USB.
Any recommendations?
TIA,
David
Archived from groups: alt.sys.pc-clone.dell (More info?)
"david" <davidg35@cox.net> wrote in message
news:x_xPe.71395$DW1.5114@fed1read06...
> HDD. CDROM is external made for the laptop-not PCMIA or USB.
> TIA,
> David
<crosspost slashed>
Run the (dell) diags on the hard disk first, then on the entire system if
the disk is found to be okay.
> TIA,
> David
"NoNoBadDog!" <no_@spam_verizon.net> wrote in message
news:SEBPe.16890$_f.12805@trnddc03...
>> 35 minutes remaining then freezes up. The hard drive was reformatted
>> every time I tried to load XP. Machine specs are: PIII-700, 256MB RAM,
>> 30GIG HDD. CDROM is external made for the laptop-not PCMIA or USB.
>> TIA,
>> David
> From the Microsoft KB:
> http://support.microsoft.com/defau [...] duct=winxp >
> Bobby
I'd reset the BIOS to factory defaults and ensure I had the latest BIOS.
I've installed it numerous times on my Inspiron 1200, which is the exact
same machine.
this reply only to alt.sys.pc-clone.dell where it was read.
remove it from the docking station if you have one and remove any usb or
pcmcia devices (other than the cd rom of course).
> TIA,
> David
>> TIA,
>> David
> Bobby
Thanks, I removed the battery and that was the problem. Good to go.
