Archived from groups: alt.internet.wireless (More info?)
hi,
i want to create a home wireless network. i have ntl broadband internet,
which is a 150k. i have a pc with usb ports, and a new laptop. i want to
create a wireless network, and want to know the following?
(BELKIN)
wireless router- f5d6321uk4
pc card (laptop)- f5d6001uk
(will need to get usb adpater, to connect directly to pc)
1. are the above devices correct for my use?
2. wat r the main differences between 'b' and 'g'. in terms of speed,
compatibility. will it appeal to me, as i have a slow internet speed.
3. can i use the laptop only, if the pc is off. (e.g. will the speed of the
laptop increase, as the pc is off, and therefore not using bandwidth.
4. can i share, and play games over the connection. (e.g. play unreal, halo,
over the wireless network from pc to laptop?)
5. can u explain the main advanatges and disadvanatges of this network?
6. r all the devices i want to buy, compatible?
"Devin Panchal" <d.panchal@ntlworld.com> wrote in message
news:NTSFc.71$Nh3.26@newsfe3-win.ntli.net...
> hi,
> (BELKIN)
I don't know Belkin equipment. If the f5d6321uk4 is really a router, and not
just an AP, then it sounds like you have the right equipment. A router will
have a wireless port, usually 4 Ethernet ports, and a WAN port to connect to
an ADSL or cable modem.
There are two numbers that get tossed around - throughput and bitrate.
Bitrate is the speed at which bits can move through the space between your
laptop and the router. Throughput is the actual effective rate at which you
can move data between the laptop and the other endpoint.
The maximum nominal 802.11b bitrate is 11 Mbps, and for 802.11g it is 54
Mbps. Actual throughput will never exceed about half of these rates - 4-6
Mbps for 802.11b, 18-22 Mbps for 802.11g. When you're transferring data to
the the Internet, your throughput will be limited by your broadband
capacity - in this case 150k (what units is that in - bits/sec, bytes/sec?).
the
The pc only uses bandwidth if it's moving data. If it's not running an app
that moves data on the wifi net, turning it off won't help.
halo,
Should be able to.
The main advantage is convenience - you don't have to run wires all over the
place to network your laptop from anywhere you want. Even for immobile
devices like the PC, it eliminates cables.
A second advantage is that you will be able to connect your laptop to wifi
hotspots anywhere in your city - some of them may be free.
The main disadvantages are the potential for interference, and security.
Wifi shares unlicensed spectrum with lots of devices (cordless phones,
Bluetooth, other 802.11 networks), which can cut your throughput. Unless you
use encryption (WEP, WPA), freeware tools used by hackers can monitor and
record what goes over your network. Many of these tools can crack WEP, with
enough data. If you run an unencrypted network, be aware that *anyone* who
gets a strong signal can connect to your network and use your internet
connection. This is the most serious problem - unless you intend for the
whole world to use your net.
In general, if you use WEP and change keys frequently, security and
unauthorized use shouldn't be a problem.
Yes. You should know that 802.11b and 802.11g are mostly compatible with one
another. All 802.11g adapters can connect as 802.11b devices to an 802.11b
router or AP, and 802.11b adapters can connect to 802.11g routers or APs
*if* these have been configured to support hybrid networks. Mixing "b" and
"g" devices in a "g" net is not really advisable, because the "b" devices
have a tendency to drag the whole net down to "b" throughput levels.
some more questions.
1. wat is the range of the wireless network. and through walls.
2. does adding all the software/drivers, etc. slow the peroformance of the
computer down. (e.g. does it add anything to startup and registry startup.
e.g. msconfig??)
thanx
devin
"gary" <pleasenospam@sbcglobal.net> wrote in message
news:2FWFc.11160$xk5.8801@newssvr24.news.prodigy.com...
> > hi,
internet,
> > (BELKIN)
not
will
to
you
bytes/sec?).
> the
> halo,
> Should be able to.
the
you
with
one
> > thanx
> > devin panchal
news:2HCGc.1048$qD.1039@newsfe3-gui.ntli.net...
Varies greatly, depending on transmit power, receive sensitivity, and
construction materials. Look up your equipment's specs on the web - I'm sure
Belkin has a website. As a general rule of thumb don't expect better than
300 feet outdoors with off-the-shelf equipment, assuming no obstructions or
interference. With better antennas, signal boosters, etc., - and the right
line-of-sight conditions - you can do several miles. Indoors, I wouldn't
count on better than 100 - 150 feet, and it could be much less. It depends
on how many walls and floors the signal must pass through, and what they're
made of.
> e.g. msconfig??)
If you have a 200 Mhz processor with 64 meg of memory, adding wifi will
probably be noticeable. If you have a more modern computer with hundreds of
megabytes of memory and processor performance measured in Ghz, you shouldn't
notice it, any more than you notice the Ethernet. Any networking adds
drivers and registry entries, and generally a config utility that starts
automatically unless you disable it.
Some people report a performance hit when they use WEP on older 802.11b
adapters, probably because the encryption is being done in the driver and
not in the chipset (and their PCs have no compute headroom). Modern chipsets
do WEP and WPA support in silicon, so there should be no performance hit for
it.
> thanx
> devin
> > > hi,
> internet,
to
> > > (BELKIN)
> not
> will
connect
> to
your
> you
4-6
to
> bytes/sec?).
of
> > the
app
> > halo,
> > Should be able to.
network?
> the
wifi
> you
and
> with
who
> one
802.11b
and
devices
> > > thanx
> > > devin panchal
