Archived from groups: microsoft.public.windowsxp.messenger (
More info?)
Greetings Steve,
If you're using MSN Messenger (*not* Windows Messenger), open the main Messenger window,
click the Tools menu, then Options, then General tab, uncheck "Allow automatic sign in when
connected to the Internet" and click OK.
If you're using Windows Messenger (more than likely), the easiest solution would just to be
to remove your saved .NET Passport so it can't login. To do so, click the Start Button, then
click the Control Panel. Then, click User Accounts in the Control Panel. Select your account
name, and then on the left side of the screen, under Related Tasks, click 'Manage my Network
Passwords'. In the window that opens, click the Passport.Net\* (Passport) entry and click
'Remove'.
____________________________________________
Jonathan Kay
Microsoft MVP - Windows Messenger/MSN Messenger
Associate Expert
http://www.microsoft.com/windowsxp/expertzone/
Messenger Resources -
http://messenger.jonathankay.com
All posts unless otherwise specified are (c) 2004 Jonathan Kay.
You *must* contact me for redistribution rights.
"Steve" <newsgroups2004@libero.it> wrote in message
news
Ykod.46102$Es2.999896@twister2.libero.it...
> Why when I connect to internet the messeger do the login? I want to disable
> this feature...what is the way?
