Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Problem with MSN Messenger Audio Conversation, Video Confe..
Forum Windows XP : Windows XP General Discussion - Problem with MSN Messenger Audio Conversation, Video Confe..
Archived from groups: microsoft.public.windowsxp.messenger (More info?)
Help Please!
I am using MSN Messenger Version 6.2 (6.2.0137).
Windows Messenger is also installed.
Whiteboard and application sharing, Sound, video and file transfer do
not work (nothing works), I can only Chat (typing) messages.
Looking in Tools/Options/Connection I have the following message:
You are connected to the Internet through a UPnP port restricted NAT
(Administrator)
McAfee Firewall 4.0, with the Firewall on or off none of the listed
features in MSN Messenger works.
I'm connected with a Linksys BEFRS41 router with the following setup:
Firmware Version: 1.46.02
UPnP: Enabled
Firewall & NAT: Enabled
DMZ: Not Enabled
Port Forwarding:
TCP,UDP: 1024-1064,1863,6901
TCP: 1503,1720,1731,522,389,1503,5190,6891-6900
UDP: 6801,2001-2120
UPnP Forwarding:
TCP: 389,5190
Note: I enabled UPnP Forwarding because I ran out of space to enter
ports under Port Forwarding.
I also have a Static IP Address configured IP Address is:
192.168.1.20. Do I need to have a Static IP Address when I have Port
Forwarding Enabled?
I am running Windows XP with SP2
Thanks in advance,
Rick
Sponsored Links
MSN Messenger 6.2 audio/video requirements:
1. If using a modem/router it must be UPnP compatible. Set Zone Alarm to
medium or shutdown, but if you are proficient with the settings, allow MSN
Messenger 6.2.0205 access to the Internet.
2. On the Network Connections, right click Local Area Connection, go to
Properties, and the General tab should show a check mark only on Client for
Microsoft Network, and Internet Protocol (TCP/IP). No check on File and
Printer Sharing for Microsoft Networks, nor on QoS Packet Scheduler.
3. The Windows Firewall should be ON (recommended) and no check in Don't
allow exceptions . The Exceptions tab will later show the MSN Messenger
6.2.0205 and UPnP Framework as being active.
4. In the Control Panel > Add Remove Programs > Add Remove Windows
Components, scroll to Networking Services and remove all checks, except for
Internet Gateway Device Discovery (A), and for UPnP User Interface (B). Click
Ok, Next, and after clicking Next the Windows Wizard Component will run.
Click Finish; now the UPnP will automatically open all required ports.
5. Sign in on Messenger and run Audio/Video Tuning Wizard. In the Tools >
Options > Connection tab, you should read You are connected to the Internet
through a UPnP symmetric NAT. (Administrator); if you are using a dial-up
line it will read You are connected to the Internet using a direct
connection. Now check the Windows Firewall Exceptions list, the MSN Messenger
6.2.0205 and UPnP Framework will now have a check marks and the required
ports automatically opend.
6. Both Windows XP users sides should have similar setups, with working
webcams and microphones. Remember that one side can have dial-up and the
other a UPnP compatible modem/router.
(A) Allow you to find and control internet connection sharing hardware and
software that uses UPnP.
(B) Display icons in My Network Places for the UPnP devices detected on the
network; also opens the required Windows Firewall ports.
Hope this will help, it has with many people. Your friend, Efrain.
"Rick" wrote:
> Help Please!
> (Administrator)
> UPnP: Enabled
> DMZ: Not Enabled
> Port Forwarding:
> UDP: 6801,2001-2120
> UPnP Forwarding:
> TCP: 389,5190
> Forwarding Enabled?
> Thanks in advance,
> Rick
Reply to Anonymous
Hi, The simple reason is the software which you r using is not correct.
Load Windows live Messenger 8.5 and u will be able to do what you want.
Thanks
Abhishek
abhishek20885@gmail.com
Reply to abhishek20885
There are 1187 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
  • 01:00 Kiren won the Uniformed badge
  • 01:00 WookinPaNub won the Uniformed badge
  • 01:00 kwadams won the Uniformed badge
  • 21:57 brockh won the Sophmore badge
  • 01:00 xpax won the Freshman badge
  • 01:00 Mizoguchi won the Freshman badge
