G
Guest
Guest
This is the second computer I have built. No problems with the first one but I can't seem to get this one stable at ALL. Here is my setup:
Deer 300W AMD approved Power Supply
ASUS A7V266-e (w/ raid and onboard audio)
AMD Athlon xp 1600+
Two (2) 256 sticks of Mushkin pc2100 DDR
Eagle Nvidia GeForce 2 GTS Pro
Soundblaster Audigy Gamer
Maxtor 20GB 7200rpm HDD - 1 partition only
TDK 24x CD-RW
Realtek NIC connected to Toshiba Cable modem
Microsoft Optical Intellimouse
Generic Keyboard
Generic Floppy
Windows ME
APC Back UPS 500v (300W)
I am not using the raid function. I am not using the onboard audio. I have Win XP but upgrading from ME has no noticeable effect on the stability of the machine. I have both the Comp and the Monitor going through the UPS.
Here is a list of the things I have tried to do that haven't worked. Please help me think of other things I can try.
1) All mboard jumpers set to default (except switched to Palomino)
2) Disabled onboard audio in the BIOS
3) Set IRQ 5 to Legacy only
4) Plug directly into wall instead of going through UPS
5) Remove sound card and uninstall drivers
6) Switch out video card (changed to GeForce 2MX 200)
7) Set all BIOS settings to default (AGP fast-write disabled and Memory speed is conservative)
8) Disconnect cable modem and remove NIC
9) Delete partition in fDisk and reformat drive, fresh install of OS
10) Download latest drivers (audio, video, and Via 4-in-1 directly from the internet instead of loading off of CD)
11) Fresh install without loading Via 4-in-1 at all (only Nvidia drivers)
12) Switch from latest video drivers (23.11) to older version (22.80)
That is all I can think of and I still have an unstable system. This is the best resource I know of. Does anyone have any suggestions on other things I might check?
I want to get this thing rock solid first, then I can start tweaking a bit to improve performance. If only I could get it to stop turning itself off or freezing up every few minutes...
AMD Athlon xp 1600+
TDK 24x CD-RW
Generic Keyboard
Generic Floppy
Windows ME
