I had a Gigabyte 7ZXR with Dual BIOS. I tried to manually tweak the bios file, flashed the BIOS and i hoped that if something goes wrong the Dual BIOS would do it's job, but it's did not work.
It seems that the Dual BIOS feature is bios based, so if the Bios is corrupted , Dual BIOS doesn't work.
Does anyone know what to do? I've sent e-mail to Gigabyte and i didn't receive a reply. The motherboard does not have a jumper to select the BIOS.
The BIOS chips are soldered directly to the motherboard (surface mounted) , so i cannot remove them easily. (does anyone know if i enchange the two chips on the motherboard , will it do the work?)
