Runtime Error! problem
Forum Windows XP : Windows XP General Discussion - Runtime Error! problem
Archived from groups: microsoft.public.windowsxp.messenger (More info?)
I receive pop-up window about every five minutes that states the following:
Microsoft Visual C++ Runtime library
Runtime Error!
Program: C:\Program Files\Messenger\msmsgs.exe
R6025 – pure virtual function call
I couldn’t find msmsgs.exe file in the above directory; however, I didn’t
manually delete any files from any directory except My Documents folder. I
also didn’t manually modify any Registry settings. I have Compaq Presario
R3240 notebook with 512MB of RAM running Windows XP Home Edition SP 2. I
would appreciate any suggestion about how I can fix this annoying problem.
Sponsored Links
Greetings Logic,
Do you happen to have Norton Antivirus installed by any chance? If so, recent versions of
Norton Antivirus added a new "instant messaging scanning" feature, which can conflict with
Messenger and cause it to also keep starting. To stop it, open Norton Antivirus (Right-click
on the Norton Antivirus icon in the System Tray/Notification Area (by the clock), choose
'Open Norton Antivirus'), click Options, then Instant Messenger then uncheck MSN Instant
Messenger (or Windows Messenger depending on version) and click OK.
____________________________________________
Jonathan Kay
Microsoft MVP - Windows Messenger/MSN Messenger
Associate Expert
http://www.microsoft.com/windowsxp/expertzone/
Messenger Resources - http://messenger.jonathankay.com
All posts unless otherwise specified are (c) 2004 Jonathan Kay.
You *must* contact me for redistribution rights.
"Logic Low" <LogicLow@discussions.microsoft.com> wrote in message
news:685B4657-501A-41B6-819C-902DEC042B0A@microsoft.com...
> Runtime Error!
> R6025 - pure virtual function call
> I couldn't find msmsgs.exe file in the above directory; however, I didn't
> also didn't manually modify any Registry settings. I have Compaq Presario
Reply to Anonymous
Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Runtime Error! problem
There are 639 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
