Archived from groups: microsoft.public.windowsxp.messenger (More info?)
Jonathan, You replied to my 1st post sveral days ago
where I was experiencing a problem with audio
conversations dropping after being connected for several
minutes.
The following are excerpts from that post:
>> Finally seemed to get all of my firewall and port
issues
>> squared away and everything seems to work except for a
>> problem with audio conversations. Am using Msg 7 on
both
>> ends and the conversation establishes fine. However,
it
>> wants to drop the connection several minutes after the
>> connection has been established. At this point we
simply
>> re-establish an audio connection and everything is fine
>> for another couple of minutes...Any ideas..thanx in
>> advance....L
You responded :
>I'm not exactly sure what's going on (especially since
this is a beta release) but I'm
>curious about you and your contacts' networking
configuration.
>Also, have you happen to try video and noticed the same
effect?
>____________________________________________
>Jonathan Kay
>Microsoft MVP - MSN Messenger/Windows Messenger
I reponded :
We are both running Sprint DSL (Zyxel 645 modems)...
Both running XP Pro SP2 (thus the initial problems with
firewall and QOS scheduler)...
On my end I am running the Sprint modem into a Linksys
(WRT54G) wireless router...
I running DHCP from the Linsys Router to a couple of
wireless PCs on this end...
On the other end, the Sprint Modem is the only device on
the network....
I have not tried video from either end....
Current State of problem :
I have since knocked down both modem and router :
I have reconfigured Sprint Modem to defaults :
I have replaced Linksys Router with a brand new one :
I have uninstalled MSN 7.0 (completely incl registry) :
